RE: YS 61 replacement motor?
O.S. MAX-61 VF
The O.S. MAX-61 VF is a high performance engine that has been developed expressly for FAI Pattern Competetion. It employs Schnuerle scavenging and a rear exhaust port to facilitate the installation of a tuned silencer system, especially where the latter is to be built into the fuselage.
This engine features specially developed ABC type piston/ cylinder construction and a 17 mm O.D. crankshaft of heavy duty alloy steel in order to provide extra power and durability and is equipped with an O.S. Type 7D carburetor, specially designed to give good throttle response.
SPECIFICATIONS
Displacement……………9.95 c.c.(.607 cu. in.)
Bore.....................24.0mm...(.945 in.)
Stroke..................22.0mm.…(.866 in.)
Practical R.P.M…………2,000 ~ (17,000 r.p.m.)
Power output………....…1.8 PS (17,000 r.p.m.)
Weight………………………….528 g (18.6oz.)
_________
Schpankme
“Take every chance you dare, I’ll still be there, when you come back down.” - Nickel Creek
