RCU Forums - View Single Post - kavalier surface throws
Old 07-03-2004 | 10:23 PM
blw's Avatar
blw
Default RE: kavalier surface throws
My instruction book gives this as the suggested beginning adjustments:
elevator 7/16 up and down
rudder 5/8
ailerons 7/32 up and 5/32 down with the neutral point being slightly above the WT plane. WT is the ply piece at the wing center trailing edge. If you have nylon bolts for wing attachment, they go thru this piece.
You didn't ask about CG, but I measured from the plans and it is 3 1/4" from the leading edge for most forward, and 4 1/8 for most aft for aerobatics. The aft CG comes with the usual advice about being an expert pilot before trying it.
Hope this helps.
