RCU Forums - View Single Post - All around best Sim
Old 07-04-2004 | 09:14 AM
Default RE: All around best Sim
ORIGINAL: STLPilot
Yes you can assign up to 12 channels. 5 on your TX and 7 on your keyboard. No prob! You can also assign, for instance a single channel that turns your smoke on, gear goes up and flaps are up. That same channel can lower the flaps, turn the smoke off and put the gear down. So 1 switch can operate your plane for landing or flying configuration. You can use a key to drop a bomb. You can also use keys for opening canopies, glider towing release, turn and rotate nozzle for the harrier, brakes, open and close doors and bunch of other options.
You can even use AFP for control line!
Please help!!
Downloaded both of those planes pictured above & also that Mitsubishi Zero that drops a reserve tank. Each of them either drop their bomb or release their missle the very moment that they're on the runway without me doing anything.
I know how to assign channels from the menu (I think it's called "calibration"?) however there is no place in there that has "bombs" or "missles" to select from.
I tried reading the "read me" but it's in German!! How do you calibrate it so that it releases it by transmitter or keyboard?
Brad
