RCU Forums - View Single Post - DA 50 do not idle down in flight. Help.
Old 07-04-2004 | 10:34 AM
wvr's Avatar
wvr
Default RE: DA 50 do not idle down in flight. Help.
I agree: to lean on the low-needle, try the following, open up the low-needle, the high rpm will be to rich, so you have to close that one a bit. Try this with small adjustments. You will find a point where the engine can idle all day long, and still pick up for full power.
Winfried
