RCU Forums - View Single Post - Prop comming loose
Old 07-04-2004 | 11:54 AM
CougarRules's Avatar
CougarRules
Default RE: Prop comming loose
On the backplate there should be two little pegs that the prop should rest against so it dosent undo the nut when you whack the starter on, at least there were on the spinners i used to use before i discovered the domed nuts these are much much better with less vibration etc.
