RCU Forums - View Single Post - Bigger wheels or smaller prop?
Old 07-04-2004 | 07:07 PM
RCforlife
Default RE: Bigger wheels or smaller prop?
I also had the same problem with my avistar. I'm also using a 10X6 prop. All I had to do was loosen up the collars on the nose wheel and extend the gear lower. This solved the problem. Just don't extend them too much or the gear will pop out of the engine mount if you have a hard landing on the nose gear.
