RE: dazzler control surface! help
You're Engilsh is just fine, so no apology is needed. I can't speak Portuguese, so please permit me to apologise.
The Dazzler will roll pretty fast with the aileron rates as it is. Don't set up a higher aileron rate until you have flown it a little.
The elevator high rate could use a little more if you feel you can handle it. Go ahead and raise the elevator high rate to 3/4". You can add more later if you feel you want to.
