RCU Forums - View Single Post - dazzler control surface! help
Old 07-05-2004 | 12:14 AM
raideron's Avatar
raideron
Default RE: dazzler control surface! help
Hi scolpit,
I also have a Dazzler.. If this is your first sport plane, The low rate setting
will be good, It will still roll pretty fast!! At Hi rates+ it gets wild!! Make sure
you get the CG on the rec. spot.. 3" back of L.E... You said your were
programing your computer radio, So I guess your going to use dual rates..
You can get her a few mistakes high and give it a try on hi rates!! She
also land pretty slow and easy as long as your light on the sticks..
Have fun!!
