RCU Forums - View Single Post - Is it possible to burn an engine with the wrong size prop?
Old 07-05-2004 | 11:54 AM
phread59
Default RE: Is it possible to burn an engine with the wrong size prop?
Yes a 10-4 is small for this engine. An 11-6 would be a good place to start. If you under prop an engine you certainly can tear it up. I would look for a bigger prop. I like APC's myself. Try one in 11-6 and see how it flies. It will have a lot more power and less speed.
Mark Shuman
