RCU Forums - View Single Post - Prop comming loose
Old 07-05-2004 | 02:19 PM
xed
Default RE: Prop comming loose
I recommend getting a Prop Nutt.. They are easier to work with, they are easy to check if they are tight or not and take no time to put on and take-off when you break your prop. With the spinners, it is just another potential hidden problem that you may not notice until it is too late.....
