RE: TNX anybody???
the biggest tip i can give you guys is take apart your diffs and replace the stock self tapping screws that hold on the ring gear with some machined 3mm screws of the same length.my stock screws started backing out and luckly i noticed it before it was to late.
another tip, take the tranny scres and loosen them push tranny towards engine and tighten scres.next loosen engine screws and push engine towarsds tranny anf tighten screws.
buy some extra spurs (terra crusher spurs are the same). dont run slipper all the way tight.
