the biggest tip i can give you guys is take apart your diffs and replace the stock self tapping screws that hold on the ring gear with some machined 3mm screws of the same length.my stock screws started backing out and luckly i noticed it before it was to late.
Will normal hex head hex screw fit?or do they ahve to be counter sunk?
