RCU Forums - View Single Post - getting hinges right
Old 07-05-2004 | 09:00 PM
majortom-RCU
My Feedback: (40)
Default RE: getting hinges right
Getting your hinges centered on both surfaces matters somewhat, but being off is no great disaster as long as the surface moves without binding or snapping. The more I hinge, the more careful I try to be about putting everything neatly on the center line, getting the hinge pins (on pinned hinges) all on the same axis. I like the GP/Dubro/Klett pin type hinges, but on some installations I like the Robart hinge points better, and on most ARFs I substitute Radio South CA hinges for whatever is in the kit. I tried the GP hinge slotter, wasn't thrilled with it, sold it after using it once. I seem to do well with the Dubro hinge cutting tool, the fork job with the picking tool, used for pin type hinges. I start the hinging process with a ball point pen line straight down the middle of each of the facing edges. I bevel down to that line, then cut carefully, trying to stay perfectly on that line. It's never perfect, but it helps to come close.
