RCU Forums - View Single Post - X-29 CG Question
Old 07-06-2004 | 09:14 AM
Johng
Default RE: X-29 CG Question
ORIGINAL: Flypaper 2
Make a small balsa chuck glider of the same scale dimnsions with a profile fuse and add weight to the nose till it gives a long flat glide. If you have a side profile, just ahead or the main gear struts is a good place to start. Did the Viggen, among others, this way.
I would do this as well, but the long flat glide is not your critical condition. WHat you want to do is make the canard adjustable - use a straw or dowel as an axle. The critical aspect on a plane like this is uncontrollable pitch-up. When you get the elevator/canard control past a certain point, the plane will continue pitching up until it is inverted, if the CG is too far aft. It would either flip over at takeoff and slide down the runway tail first, or pull-off a figure 9 when on approach.
The problem is, it will fly just fine when trimmed for level flight. So, you need to check the CG for slow flight characteristics. Set the canard for 20 deg pitch up. Adjust the CG so that when you gently toss it the nose hangs up high while the glider flies slowly but maybe not so efficiently. THis will ensure that the plane will remain controllable at low speed.
As for using the rear fuselage strakes for control, the shape of the surface will not allow very much control power at all. You should keep it simple and use the canard for pitch control.
