RCU Forums - View Single Post - rush evo wont move
Old 07-06-2004 | 12:03 PM
Frost_'s Avatar
Frost_
Default RE: rush evo wont move
When the bottom coil on your glow-plug goes bad the engine will usually idle but then just die. If you remove the the plug and check it, the entire coil must glow, every coil..... And if you are unsure, replace it.
Try a new plug.
