RCU Forums - View Single Post - using 4c crankcase pressure with chech valve?
Old 07-06-2004 | 03:15 PM
Ernie Misner's Avatar
Ernie Misner
Default RE: using 4c crankcase pressure with chech valve?
Huh? A 4 stroke crankcase pressurizes on the up stoke and pulls vacuum on the down stroke doesn't it? Whereas a 2 stroke pressurizes on the down stroke and is more neutral on the upstroke due to the intake (carb) port opening.
I don't see why you would want to use crankcase pressure (or try to) on a 4 stroke.
Ernie
