RCU Forums - View Single Post - Dazzler aileron neutral settings?
Old 07-06-2004 | 07:24 PM
1wingman
Default Dazzler aileron neutral settings?
Hi all, this may sound like a dumb question so bear with me. I just finished putting together a Dazzler ARF and am not sure where the aileron "neutral" position is. I have it set up so the tips of the ailerons are flush with the bottom of the wing. (I laid a straight-edge across the bottom of the wing and set the aileron so the angle was zero degrees with respect to the bottom of the wing.) From the top of the wing it looks kind of funny though because it looks like the ailerons are raised. Hopefully my description was adequate. Is this the correct neutral position for the ailerons?
Chris
