RE: Dazzler aileron neutral settings?
1wingman, I would adjust them so they are even with the center section of the wing. Draw an imaginary line thru the end of the wing front to back, centered top to bottom. Line the aileron up with this line. After you fly it for a while and get use to it you might want to try going in a couple of turns on the clevis on both sides, fly it, then back out 4 turns and fly it. Judge for yourself where you like it best after you play with it for awhile.
Ed M.
