RCU Forums - View Single Post - dazzler control surface! help
Old 07-07-2004 | 12:28 AM
davidinmi
Default RE: dazzler control surface! help
The Uproar is a very nice flying plane and I assume the Dazzler is also. I would highly recommend flying with an instructor for several flights. The plane takes off very nicely, flies great and is easy to land. Where you have to be careful is keeping track of which way it is going and which side is up. It is a small plane and it can roll very quickly. It flies almost the same upside down as right side up. Where it will bite you is when you lose track of it and command it to go the wrong way. Good luck. My second one is a lot of fun, my first one did not last long.
Dave
