RE: balancing
To answer your question you balance it with the tank empty. Follow the directions and you will be fine. I don't have a balance tool yet. I just use my fingers. It it not the most accurate in the world but its close enough. Just put a finger on each side of the wing on a rib at the distance from the leading edge that is specified.
It should lean forward just a tad but not nose over.
