RCU Forums - View Single Post - Charge Leads?
Old 07-09-2004 | 10:40 AM
ezflyr
My Feedback: (32)
Default RE: Charge Leads?
OK, I'm using a Schultz Cham. to charge my ECU batt but have not used that charger for the Rx batt because it calls for a 2.5mm charge lead?
Hi!
I think you might have misunderstood what is being said! I'm not familiar with your charger, but presumably the charge leads use "coaxial" barrel type connectors?? If so, the "2.5mm" refers to a particular standard size coaxial connector, and not to the wire diameter!! Go to Radio Shack, and you will find that they have all the standard size coaxial connectors!
John
