RE: HELP
If it was running before you did the gasket job, it is obvious that you disturbed something while you were working on it. Recheck the glow plug, linkage etc. Also, make sure it's getting fuel, perhaps your new fuel filter is in backwards, or is somehow blocking the fuel flow. Like I said, if it was running before, you'll figure it out and get it running again.
Jag
