RCU Forums - View Single Post - Super Flying Models Eindecker
Old 07-09-2004 | 11:38 PM
  #73
BULL-RCU's Avatar
BULL-RCU
My Feedback: (15)
Default RE: Super Flying Models Eindecker
Thorsten
The plane is so gentle that it's not that critical. The rudder you can put as much as you want. The alerons I would put in 1/2 inch up and down. The elavator you can put in 1/2 to 3/4 inch. If you have expo just put about 30% on the alerons just to soften the sticks... or non at all. It's an easy plane to fly... For the first flight I would look at the elavator and put just a couple clicks of down. Most find what looks to be level makes the plane climb. Everyones first flight the plane seems to want to climb. I've got a 100 flights on mine and it's very easy to fly. On landing the first couple times you try it might try to bounce a little because the gear is so stiff. The plane will sloow down to a crawl speed and when it does you will need the elevator to hold it steady and land soft. Don't be nervious it's a great and easy plane to fly... Slow it down in flight and see how the crowd reacts... They won't beleave how slow you can make it fly.... Good luck and let us know how it goes.
