RCU Forums - View Single Post - Prop balancing
Old 07-10-2004 | 09:16 AM
ml3456
Default RE: Prop balancing
Ken,
Agree with you. I have many props, both large and small that are out of ballance at the hub, not the blades. I get it so that each blades are balanced and then do some slight balancing of the hub so that there won't be a heavy side. Also, when a prop is as out of balance as the one in the picture, the hole was probably not drilled on center.
mark
