RE: OS 46 FX or AX
Thanks for your info Ron,
I managed to get a member at the field today and he has a lot of engine experince so we fired it up and
sure enough I was getting an endless stream of air bubbles that was he believes to be the main problem. He got it adjusted nicely
but I guess I got to remove the fuel tank again to try to find out where the air is coming from. He believes the engine was not
damaged as I was running it actually to rich so he adjusted this and also my fuel line was way to long causing some of the bubbles
from vibration so we shortend that up and it did help some. Engine really sounds good now with a lot better transition but those air
bubbles are making it run a little off so thanks for your help and I greatly appreciate it.
Air Hawk
