RE: First plane suggestions?
its fine to start off with a park flyer instead of the .40 size trainer you will be bombarded with here, but not either of the 2 you listed...check the GWS line,, look at the parkflyer forum under electrics..if thats the route you want to go............you most definately DON'T need to start with a .40..its just a common misnomer that is argued here..........Rog
