RE: AVOID THESE ARF's AT ALL COST!!!!!!!!!!!!
While on the subject of VMAR I thought I should add a few comments about the old VMAR Stick 60. Though I can't comment a whole lot about the Aero Subaru I have because it does not have sufficient Flight Time to make a good analysis, I can post a few comments about the Old Vmar Stick 60. The Old Vmar Stick 60 has very thin slab sides which can virtually be puntured just by picking the Model up. Also the tail section of the fuse is extremely weak. I had to build a Ply Collar around the back part of the fuse on the Vmar Stick 60 to keep it from busting off. Being a Tail Dragger the tail will not handle the stress of Takeoffs,landings, and Taxi's. I can safely put this Plane on the list of ARFS to avoid at all cost.
