RCU Forums - View Single Post - Help needed on First Engine Startup
Old 07-31-2003 | 09:37 AM
gareth_uk
Default Help needed on First Engine Startup
I've recently purchased a Irvine Tutor 40 with a Thunder Tiger GP 42 engine. Planes built but i have the following question.
1 - As standard the engine carburetter had a tube inlet and i was supplied a needle valve as an extra. However if i unscrew the exisiting part the needle valve doesnt fit or screw in to the carb.
I tried to start the engine but nothing happend.
I've noticed if i turn the engine by hand it rotates but does get fairly stiff at a point. Once i've applied more presure it turns. How stiff should the piston be when moving the prop by hand.
2 - when i increse the throlle the rudder also turns (even though they are seperate servo's
3 - Is the need valve even needed?
many many thanks
gareth
