RCU Forums - View Single Post - About glow starters
Old 07-11-2004 | 07:07 PM
LuckyArmpit's Avatar
LuckyArmpit
Default About glow starters
I'm new to engines. Have ran about 3 tanks in my OS .46 AX. About these glow starters. I have a Hobbico one. Its charged up and
fires up the engine 1st time! After I run the tank out, I re-fueled and waited about 15 minutes to half hour. Fired it up again.
Adjusted the needle and ran lean and rich according to engine manual. Well, I started screwing around moving the throttle up and down
while moving the needle. Engine quit. Tried to re-start a bunch of times but the engine wouldn't kick over. How many times can the glow starter be used before it needs charging? Or, did I run too lean and heated up the engine and it just quit because of heat? Trying to get this adjusted so I can move the throttle so it don't bog....
Dave...
