RCU Forums - View Single Post - Kingcat range check
Old 07-11-2004 | 09:06 PM
RCUser012
Guest
My Feedback: (73)
Default RE: Kingcat range check
how is your RX antenna routed ?? its stuff like this that has me using the long whip antennas .. on sport jets, i dont mind the antennal all that much ... but some people do not like them ...
If you have the antenna route in the wing as per the KingCat design, i do not see there being a problem with that ... is your RX by any chance right next to any fuel pump ? ECU ? solenoids (yea, i have see n issues with this) .... also, try to not run any servo extensions or leads around where the RX antenna wire is ...
Wojtek
