RCU Forums - View Single Post - firebird commander
Old 07-12-2004 | 05:53 AM
maiochine
Default RE: firebird commander
hello there!!!!
Responding on your question i can say that to execute a Looping with your FireBird Commander is not a big deal!!! all you have to do is :
1-not attempt to execute the looping on your first 5 flights....wait a bit to earn some experience.
2-When you get into the Proffessional mode DO NOT attempt to execute Loopings on your first flight Pro. wait and earn some experience on that mode.
3-When you get ready in Pro. Mode i can tell you one thing that i experienced one mounth ago: FLIGHT HIGH about 30fts (10M) above the ground,
when you're established on 30fts begin your acceleration for about 10 sec and DO NOT turn right or left, after that maintain accelerating and trun at the same time in a way
you can get wind direction on your tail DO NOT and EXTREMLY NOT continue your turn with acceleration on, for more than 6 secs because if you exceed the aircraft max speed witch is 30km/h your wing will fold up and brake and your bird will get ground faster than lightning (witch happened to me one mounth ago and fourtunatly i was flying in a 30 cm height grass field that absorbed the shock and kept the electronics safe !!!!)okay when you turn while accelerating your aircraft will gain enough speed and all you'll have to do is pull back your finger off the direction stick and than after when you aircraft is flight straight you'll have to accelerate back again with out turning so that you get the peek point and you'll see the aircraft flip back and execute the looping ...
thats all fly safe and enjoy your hollydays !!! cIAO
