RCU Forums - View Single Post - First plane suggestions?
Old 07-12-2004 | 04:23 PM
Chikokishi
Default RE: First plane suggestions?
Iv already downloaded FMS, and Preflight (the only two free flight simulators i could find) but im using a joystick instead of a plug-in remote. I goten to where i can do about anything i want to with elevator-rudder planes, ailer. ele. and rudder planes, and iv ever goten fairly good at flying jets on it. and i did get ahold of the local club (about 7 old guys who have those planes that have 7ft wingspans) iv only went flying with two of them, and i havent met the rest. But as far as i know none of them have little planes i could try or anything. Im a very quick learner, so i assume if i got a plane into the air withen a few seconds or so id pretty much figure out how to fly. and after a couple crash landings id figure those out too... But i can tell im scared to fly one because the guy i went flying with today let me see his controller and control the ailerons and stuff...while the plane wasent flying..(the engine wasent even on) and i started to shake a little. But then again the airplane was bigger then me and it kinda creeped me out a little. I just found the Slow-V from parkzone ( http://www.parkzone.com ) And im really considering buying it. Iv had lots of refferals to the f-27 styker i think it is, and its from the same company so i assume the slow-v would be great too? Most of my flying will be at a football field that has a running track around it (made out of rubber ...stuff.. it makes a good take off for my control line (whos engine has like died..dont know whats wrong with it)) so i thought it would be a perfect place for a little plane to fly. Could someone check out the Slow-v and tell me if its worth it? I seriously want to stay to something simular to the slowv or that megatech plane mentioned above. Speed right now kinda scares me cause itll hurt worse if it hits the ground [&:]
Fox
