RCU Forums - View Single Post - firebird commander
Old 07-13-2004 | 01:21 AM
tmm3
Default RE: firebird commander
I own one of these and i also own a T-Hawk check it out try readytoflyfun.com
it has a taill& rudder set up on it.
not a bad plane as well.
my comander is ok I have bought many of these planes and parts for them and am trying different things,motors wings
the electronics are not very serviable on hobbyzone planes like servos,recievers even if you want to change the motor which I have tried as well you have to open up the fusalage
To make the tail last longer I took a pin and poked it in the tip of the tail then I ran
fishing line at the top of the V to keep it from folding out. not too tight i tied a couple
fishing knots at eack end this kept the top of the tail from going flat
i also have folded some wings on high G loops i am working on putting a wire in the bottom of the wing to streanthen it when doingloops with high G.
When buying anyreplacement wing look close at them in the hobbyshop if ther are any creases in the wing thats were they bend
I don't think they are packaged well when shipped but at $15-$18 a pop
i want the best wing for my buck same with tails
Is any one using any other manufacturers wing on thes fusalagesjust curious
have fun Tmm
