Originally posted by AudiMaxx
More Questions....please bear with me
1. Do you run an Air Filter on the Carb on a Heli?
2. When advancing the throttle past 1/2...the engine tends to
loose power quickly...yet I have good smoke/oil coming from
the pipe (Running 12% Cool Power Fuel) why? Motor is an
OS 32.
3. Rotopod has me a bit shaky....It tends to tilt too much and flop
around. I would prefer that I had a flat surface to start out
with. Should I go ahead and convert it to Stage II, or should
I Reverse the Beveled Gaskets so they are flat?
Thanks in advance.....
1.A- no,to restrictive
2.A- need more info-what is the pitch @ 1/2 stick etc..
3.A- When I started out (way back when) I used to straight dowels with whiffle balls.
