RE: Rubber bands not enough!!!!!!!!!!!
Try this simple test : Do your wide-open throttle vertical dive recovery inverted. You should find the wing stays in place under the inverted fuselage. Then simply roll out.
Is this something you see other people doing? I don't recall seeing any IMAC routines that require WOT vertical dive recoveries. Just wondering.
Dave Olson
