RE: Temptation Kit
Hello guys!
Here is what is done so far!
have almost done the stab ready for sheeting. whats left is to glue in the support for the elevator horn and to cover the tube with the foam that i cutted out to install the stubes so the surface is smooth.
i used 6mm balsa in the root and glued 3mm plywood for the adjuster bracket.I aslo glued some 4 mm balsa to seal the tube in the end the rib that hold the end off the socket is 4 mm x balsa!
Rune
