RCU Forums - View Single Post - radio problem
Old 07-15-2004 | 06:45 AM
donalddresser
Default RE: radio problem
One thing to check is your throttle cable. Are your using a metal cable, if you are make sure that it is not touching anything metal. I was having problems and it ended up being that the throttle cable was rubbing on the engine case.
