ORIGINAL: N2raptor
By the way, Wright, theres a problem from what I understand with the Hitec Eclipse 7 and XTR. Seems like Hitec changed the pin configuration on the trainer jack of the Eclipse 7 without tellin anyone, so XTR won't run. A simple resolder job will fix the problem, but I think MRC is coming out with another cable or something to solve the problem.
N2Raptor[8D]
Err, not on my Eclipse 7 - I can use it just as easily as the FF6 on exactly the same cable. I just choose to use the FF6 because I don't want to keep removing the cyrstal module from the Eclipse to reduce RF power usage. I use the Eclipse to actually go and do the things I've been learning in XTR.
Cliff
