RE: About glow starters
DB and Dauntae, thanx for the tip for baby wipes!!!!! Baby'ing your aircraft!!!!! LOL!!!!!
Scar, my glow driver is from Hobbico. I don't think it will come apart. I will check though. I plan
on getting a field box and power panel. So, I will go with a glo starter that plugs into the panel
and use it. Going to run another tank of fuel today. I think I have it basically run in....I can do
full throttle and hold the plane up perpendicular and it doesn't bog out. The transition is pretty much
smooth from idle to full throttle. I will however have the intructor check it out before its flown to make
sure I got it right.
Dave...
