RCU Forums - View Single Post - EASIEST Plane to HOVER??
Old 07-15-2004 | 12:41 PM
lionheart's Avatar
lionheart
Default RE: EASIEST Plane to HOVER??
Thrust to weight ratio obviously needs to be higher on the thrust side of the equation. Size of control surfaces that the prop can flow air over as well. Depends on airframe, weight, thrust, prop..... lot of variables to consider. Foamie profiles have the advantage in weight compared to thrust, obviously.
