Super Tigre .75 won't stop
I have a Super Tigre .75 that won't quite, literally. The throttle is closed completely, no opening visable at all, in fact its closed beyond that. I thought there might be an airleak around the throttle so I seated the carb to the crankcase with plenty of pressure. Close the throttle, crank down the trim, hit the kill button on the transmitter, zilch, the thing keeps on running on a dead slow idle. Only way I can kill it is pinch off or pull off the fuel line and then it still runs for 30 seconds.
Everything else about the motor runs great. Super power, slow smooth idle, (with a tad of opening visable in the carb), great transitions, normal top end rpm.
Anyone that can tell me what gives and how to make this thing stop?
bob branch
