RE: U Can Do 3D
cline reg helps the saito alot! plus when you use it you can move the fuel tank towards the cg to help flight performance!
with the cline i notice evenier fuel mixture threw out the throttle range and havnt stalled it since, the only problem with the cline that i noticed is that it wont richen up to the point of the engine sputtering! so its alittle tricky to make sure you have the right fuel mixture. but works great!
i like it!
