PCM, is it absolutely necessary?
Chris,
My feeling is that the landing gear reacts too slowly to short duration fail-safe's. You'd never see the little ones with just the gear fail-safe'd. A quick up-elevator, however, is much more likely to be seen. Of course, the newer ECU's are starting to give you fail-safe counts, and they will be a valuable tool.
