Dual-servo elevator linkage geometry
Mike,
OK, thanks for the clarification. I guess we'll just have to agree to disagree. Personally I think you can't go wrong with most instructions from the manufacturor. This way if there is a defect they will replace the plane without blaming it on your mod. Plus servo reversers add another possible failure point.
Yet another solution would be to go with one "reversed" servo of the same brand/make. I've used digital's (reprogrammed) for this type of setup with excellent results.
Mark M.
