Dual-servo elevator linkage geometry
Andy - I was going to suggest exactly what you decided on. I had the same issue and originally used the reversing Y harness. It turned out that extreme weather conditions caused the Y harness to change my elevator trim. It was as someone else mentioned an uneeded point of failure. With all the computer radios out there, I'd think we'd all do the mixing solution. Good luck
