Hi,
If you have only got a choice of these 2 go with the 46 LA, i have a Seguls Mustang P51 althou thier cheap and look on the cheap side they do fly well......... i fly that with a 46 LA and its flys ok and loops, rollls etc ok could do with a bit more upfront in power terms..... one thing you should do with all segull models is where you screw the wing bolts onto the wing, reinforce it with a small peice of plywood to stop crushing........ just drill out 2 holes soo the bolts go throu otherwise you might fly it one day and the wing comes down before the plane
Good Luck
