RE: TowerKote vs. MonoKote
I covered my Tower Fun 51 with Towerkote. It was fine for the first few months but then the seams started to come loose, especially near the engine. Towerkote does not stand up well to fuel. If you want to keep your Uproar for several years you should not use the Towerkote. If you're happy flying it just one season then the Towerkote will be OK.
As far as application technique, Towerkote and Monokote are very similar. Just use a lower temperature with Towerkote.
