RCU Forums - View Single Post - ? for RCIGN about G26 conversion weight
Old 07-18-2004 | 10:34 AM
Antique's Avatar
Antique
Default RE: ? for RCIGN about G26 conversion weight
A glow G26 uses a glow plug. A rimfire plug is for ignition...
A glow G26 can be completely stripped of all ignition components and the case and cylinder lightened..Cut the rear crankshaft flush with the bearing and press a plug into the case instead of the crank seal...Use the old G23 style hub....There are mounting lugs on the front of the case that don't do anything, and the case can be cut off on the back flush with the cylinder....A glow G23 has a lighter cylinder than the G26 and weighs 1 1/2 lbs, turns the 18-6 about 8000 rpm....I have made three like this...You can't buy either made like of this from Horizon, don't know why......The photo is a 2 1/2 lb gas G26..
928 635 2455
