RCU Forums - View Single Post - What size wire to use for 4-40 threading die
Old 07-19-2002 | 10:48 AM
dant-RCU's Avatar
dant-RCU
Default 4-40 dies
mecam:
I have the Rodchuck system and use it to make 4-40 pushrods. The base stock is 1/8" welding rod. The Rodchuck uses a 2 die method. 1st pass is with a 5-40 die which sets the correct thread count then a second pass with the 4-40 that reduces the threaded diameter and gives the correct sizing. Works like a champ.
Any round stock will work. The test is if you can EASILY file a flat on it then it can be used to cut threads.
Dan
