RE: GWS Beaver Battery
Hi There
I too am putting together a GWS Beaver together down here in Australia. My question is right at the beggining of the construction piece there is a requirement to draw a line on the engine mount 6mm and 5mm from the side at each end and this creates a slightly slanted thrust line to line up with some part on the engine presumably further down the track. Which end goes into the a/c and which end goes into the motor end?? It does not seem to specify. Am I correct in guessing that there is a mark on the engine to line up eith it??
Kind regards
